The Daily CLAD
Community Browser
Re: CLAD2017 - Best Practice - SubVIs: 5 of 5
SercoSteveB
Active Participant
Whilst building a VI you draw a selection box around the Block Diagram elements shown in the snippet below and then select Create SubVI from the Edit menu.  Does LabVIEW create the SubVI?
a) Yes
b) No
Comments
kiranteja93
yes
AlexBY
YES, but it's not a good way according to the best practice.
Maybe is better to include the Multiply function in the subVI.
andrefcbruni
No.
LabVIEW won't let it since it'll go on a cycle when calling the VI.
nik35324
No because the input node depends on one of its own output nodes.
It creates a VI but not the sub vi in the selected program.
Spoiler
crossrulz
Knight of NI
Due to the cycle, it will not create a subVI.  But it can still create a VI out of it.
A_rid
No
kiranteja93
 thank you  nik35324 and    . i never tried this before. now after your clarification i understood what is the twist in this question.
Gab008
 no
Kuddo welcomed
CLAD-CTD
AlexBY
Very useful to understand more deeply the difference between VI and subVI.
Thank you, so also according to me, the answer is NO
Matt-A.
No. Best practice is to include all functions between the inputs and the output variable.
hemasagar
NO and its not a good practice
sumit04
Yes, it will create the SubVI,  but its not good practice
Best Regards
Sumit Memane
CLAD, CTD
A.Bernau
no, not this VI, just an emtpty VI
SercoSteveB
Active Participant
Answer: B (No).  Nice one all.
A good starting point for Avoiding SubVI Selections That Create Cycles.
istan0227
B
