The Daily CLAD
Community Browser
回應: CLAD2017 - Fundamentals - Array SubSubSubSet
SercoSteveB
Active Participant
What are the contents of Numeric Array Out following execution of the VI?
Comments
crossrulz
Knight of NI
B
SPK91
B
vidya1825
B
P Vidya sankar,
பரத்_குமார்(bharathkumar)
 B
Thanks & Regards,
Bharath Kumar
GCentral
hemasagar
Hlo frds,i am having a 2d array with 5 rows and 4 columns which is evenly distributed,1st column should be x-axis and remaining 3 columns with 3 different plots on same graph,can any one explain?
nik35324
B
AUlikyan_ANEL
B
A.Bernau
B
Baltur
B)
hemasagar
@SercoSteveB
how could we get a multiple plot in a single graph where  1st column should be x-axis and remaining columns should be the 4 plots can any one explain
crossrulz
Knight of NI
hemasagar,
You might have better luck if you asked your question in the LabVIEW discussion forum instead of spamming people with PMs and making unrelated posts in this blog.
hemasagar
Sorry for that,it won't happen again
alexderjuengere
Active Participant
B
Ganesh-kumar
Obviously B
Priya16
B
Bcortes
NI Employee (retired)
As everybody posted the answer is b, and here is why:
Baccas
B
i feel it's good quiz
mini09
Active Participant
B
The_CLoWN
The places where you can make mistake:
1> It's a while loop. So, even after condition is true it will run for that iteration as well.
2>The whole array is passed b/w the shift registers.
The answer is B.
rak84
B. If structure changed to For loop with conditional terminal the result is Ans C
crossrulz
Knight of NI
rak84,
Why would a FOR loop matter?  The action is done at the same time as the check, so it would come up with the same answer as long as N was more than 3.
rak84
Dear crossrulz,
During third iteration  array size is 2 so the condition is true and loop should stop execution and output should be {8,9}. As I learned for loop will check condition and then execute code. But  I tested the code in the third iteration output is {9}. Could you please explain why for loop is executing even though stop condition is true in the third iteration.
crossrulz
Knight of NI
"As I learned for loop will check condition and then execute code."
That only works on the iteration count.  The conditional terminal is checked at the end of the loop iteration.
After the first iteration, the array in the shift register is {6,7,8,9,10}.  After the second iteration, the array is {8,9}.  But the size comparison was done with the array before it was shrank, making the size 5, which is more than 3, so the stop condition is FALSE.  2 iterations is still less than our 3, so we move on to a third iteration.  Now the size comparison will state 2 (again, before the array was shrank), which is less than 3, so the stop condition will be TRUE (not that it matters since N is 3, which will make the loop stop here).  But the rest of the code in the loop must still complete, which takes the array down to {9}.  So the final value of the array that comes out of the shift register is {9}.
Tamir87
d
மணிகண்டபிரபு
B
istan0227
B
