Consider the VI below that creates (or replaces) two text files, TextFile.txt and TextFileLooping.txt, and populates both files from the same (very important
) data set. Assume the path exists and that both files are created successfully.
What are the contents of TextFile.txt and TextFileLooping.txt following execution of the VI.
a)
b)
c)
d)
