The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - Tony what's happening?
SercoSteveB
Active Participant
SercoSteveB has created the following VI but has poorly commented/documented his work (not for the first time Smiley Wink).  Which of the following most closely matches the functionality provided by the VI?
NOTE: All hidden cases of the Case Structure are shown below:
a) The VI records the average value for each pair of values in Numeric Array In.
b) The VI records the number of occurrences of each unique value in Numeric Array In.
c) The VI records the rolling total of values in Numeric Array In.
d) The VI records the sum of the odd values in Numeric Array In.
Comments
SPK91
B
crossrulz
Knight of NI
B
I find this easier to do with Variant Attributes
sankar06
B
Happy to Wire
A.Bernau
B
Baltur
b)
nik35324
B
SercoSteveB
Active Participant
crossrulz I find this easier to do with Variant Attributes
Could you post up an example?
crossrulz
Knight of NI
I know there are better examples out there, but this is the first good one I was able to find: https://forums.ni.com/t5/LabVIEW/count-the-number-of-repetitions-of-items/m-p/3367576#M991374
mini09
Active Participant
B
MrStevenUND
B
alexderjuengere
Active Participant
B
my favorite example is this 2007 nugget:
https://forums.ni.com/t5/LabVIEW/Community-Nugget-3-12-2007-Implementing-sets-with-variant/td-p/4899...
I used this technic in my answear to Re: CLAD2017 - Answer the Requirement - Remove Duplicate Numerics
But I really appreciate the explicite approach, using array functions only
Priya16
B
SoundNLight
Tough one!
kirti3105
B
mabaig
its B
burak1453
Answer: B, I also attached an instance
crossrulz
Knight of NI
Since this thread was just revived...LabVIEW 2019 introduced a new feature called Maps that would make this functionality even easier.
istan0227
B
