The Daily CLAD
Community Browser
Re: CLAD2017 - Variants - Friday Mind Bender
SercoSteveB
Active Participant
What are the contents of Numeric Array Out following execution of the VI?
Comments
sankar06
Ans C
Happy to Wire
Baltur
c)
It's good to see the return of the Friday Mind Bender.
crossrulz
Knight of NI
C
Timsrice
altenbach
Knight of NI
On a side note, you'll get the same result if you eliminate the second FOR loop as follows:
(Of course this might not work if the "value" is a more complicated data structure, so proceed with caution)
nik35324
C
rak84
C
istan0227
C
