The Daily CLAD
Community Browser
Case Structure output tunnels
SercoSteveB
Active Participant
Explain the difference between the Case Structure output tunnels identified by arrows A & B below?
a)      The tunnel identified by Arrow A has a missing assignment (causing the VI Run Arrow to be broken), whereas the tunnel identified by Arrow B is configured to use the default value if unwired.
b)      The tunnel identified by Arrow B has a missing assignment (causing the VI Run Arrow to be broken), whereas the tunnel identified by Arrow A is configured to use the default value if unwired.
c)       There is no difference between the output tunnels identified by Arrows A & B.  The Run Arrow of this VI is broken.
d)      There is no difference between the output tunnels identified by Arrows A & B.  The Run Arrow of this VI is NOT broken.
Comments
