The Daily CLAD
Community Browser
Re: Case Structures - State Machines
SercoSteveB
Active Participant
The following shows a State Machine VI followed by ALL of the Case Structure frames within the state machine.  What is the sequence of states transitioned by the state machine during execution:
All of the hidden case structure frames are shown below:
a) State 1, State 2, State 3, State 4, State 5
b) State 1, State 2, State 4, State 5, State 3
c) State 1, State 2, State 4, State 5
d) State 1, State 2, State 3, State 4
Comments
srinath@elsys.in
Here  Ans is  : C ........
The sequence is  State1,State2,State4,State5 In State5 case again State3 is there but here the Terminating condition isTRUE so program will stop.State3 will never execute.
Anagha.G
YES ANSWER IS C
sumasbhat
Ans is  C.. In state 3 condition is true. So program will stop.
mini09
Active Participant
Yeah i accept with srinath, ana and sumasbhat.
1. the default case is executed and jumps to the state 2
2. in the state 2 case the condition is false and the case jumps to the state 4
3. in the state 4 case the condition is false and the case jumps to the state 5
4. in this case the condition is true so the while loop stops.
YogeshShivarudrappa
Ans is C, as the state5 aborts the while loop before state3 could execute.
Calvin_Fernandez
yeah the answer is C....
hey Steve just wanted to ask you about .Net functions, are topics like that also necessary for the CLAD?
regards
calvin
ashwinilele
Ans is C
hussey
Ans :c
State 1 condition False go to
State 2 condition False go to
State 4 condition False go to
State 5 condition True, Stop the vi execution
A.Bernau
My first guess was B then I realised state5 is the final state so answer C.
Nobunaga54
I found it a good follow-up challenge to try to output the sequence of states in an array on the Front Panel.
