The Daily CLAD
Community Browser
Re: Classic Series: FOR Loops 2 of 5
SercoSteveB
Active Participant
What is Output Cluster following execution of the VI?
Comments
Not applicable
A
kirthika101
c
sathishp91
C
A.Bernau
C
ashwinilele
C.
J_M_M
A.
Base on what I understood from this question, the N terminal indicates how many times the loop will run and it would depend on the input arrays as well as the value on the N terminal. The for loop always run the fewest time possible, in this case 3 times.
Juvin
A
LordNobady
A.
Learning LabVIEW since January 2013
HaraldBraun
A
Kriti27
C
A.Bernau
OK, I was wrong. First I don’t like this implementation of LabVIEW
1. To give this information via N means it is a redundant information. After finishing the loop i has the same information (n = i+1)
2. My optical first impression was you assign a value to N and later you read the value N so it should be the same
Later I recognized you can read N=3 in the first iteration of the loop. I did not expect this. Yes this makes sense! Now I like it 😉
Thank you Steve for this special Daily CLAD to clarify this .
danielb85
A
crossrulz
Knight of NI
A
GCentral
MrStevenUND
A.  Another I didn't expect.  Thanks Steve!  That can be useful in troubleshooting!
mini09
Active Participant
Very tricky, I new that N will return the value it's been wired. But today I learned that it will give the maximum times the loop is runned.
Answer is A.
nik35324
A
rgbernatchez
A
Mohammed_Atef
Good tricky
SercoSteveB
Active Participant
Answer: A.  Nice one DavidCorney, J_M_M, Juvin, LordNobady, HaraldBraun, danielb85, crossrulz, MrStevenUND, gnshmrthy, nik35324 & rgbernatchez
This one divided opinion. Andreas23 makes an interesting point, the N Terminal doesn't look like it should modify the value wired to it......but it does and it is actually useful for post loop iteration count processing.
SUYAM
Good tricky,,thank u steve .. this is new to me.. i learned something new
sac0071
A
hemanths
Very Tricky
M.P.Bharghavi
Ans:A
3
False
