The Daily CLAD
Community Browser
Re: Diagram Disable Structures #2
SercoSteveB
Active Participant
A VI contains the following Diagram Disable Structure.  Is the VI Run Arrow broken?
NOTE:  The Enabled case of the Diagram Disable Structure is empty (contains no wiring).
a) YES
b) NO
Comments
crossrulz
Knight of NI
Yes, the run arrow will be broken.
GCentral
LordNobady
Yes
Learning LabVIEW since January 2013
A.Bernau
a
whitecr
And: A, connect default wire is not selected so LabVIEW compiler will show broken arrow.
MrStevenUND
Use Default is not selected.  It will be broken - A.
nik35324
Yes
ashwinilele
Yes
Mohammed_Atef
A
SercoSteveB
Active Participant
sac0071
A
rupesh.v
Ans=A
Nice example...
Gab008
A
Kuddo welcomed
CLAD-CTD
