The Daily CLAD
Community Browser
Re: Diagram Disable Structures
SercoSteveB
Active Participant
A VI contains the following Diagram Disable Structure.  Is the VI Run Arrow broken?
NOTE:  The Enabled case of the Diagram Disable Structure is empty (contains no wiring) and the rest of the VI does NOT contain any errors..
a) YES
b) NO
Comments
crossrulz
Knight of NI
TRUE FALSE, assuming the rest of the code is runnable.
Just realized I misread the question last night...
rsmrostov
not broken, vi runs
Not applicable
b)
A.Bernau
b
LordNobady
b.
Learning LabVIEW since January 2013
DesasterMaster
NI Employee (retired)
B
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
nik35324
NO
YES: Assuming error in the rest of the code.
SercoSteveB
Active Participant
Post modified to include a note that the rest of the VI does NOT contain any errors.
sriveni
B
a.guzman_87
B
MrStevenUND
B
shargurudk
And B. The vi wont show broken arrow
whitecr
Ans: B.
If we disable any node or wiring in block diagram LabVIEW compiler will not complie the code inside the disabled block diagram. So there won't be an broken arrow in this VI.
Nice question Steve. Pls post some other questions regarding LabVIEW compiler.
ashwinilele
B
SercoSteveB
Active Participant
Answer: B.  Nice one crossrulz, rsmrostov, DavidCorney, Andreas23, LordNobady, Dennis Amelung, nik35324, sriveni, a.guzman_87, MrStevenUND, shargurudk, whitecr & ashwinilele
whitecr LabVIEW Compiler questions coming up the week starting the Monday15th March.
ramesh44
i am quite confused with this question and the previous question both looks similar but answer is different can any one explain me why is it so
crossrulz
Knight of NI
Take a closer look at the output tunnel.
This one has a dot in the middle to indicate that the tunnel is set to "Use Default if Unwired".  Therefore you do not have to wire anything up to that tunnel in the other case.
The other question has nothing in the middle.  So that "Use Default if Unwired" has been turned off. You therefore have to wire up every case, or for the Diagram Disabled Strucuture the enabled case.  Since it was noted that the enabled case was empty, you have a broken run arrow.
