The Daily CLAD
Community Browser
Re: Error Cluster Manipulation
SercoSteveB
Active Participant
Describe the functionality of the VI?
NOTE:  The False case of the Case Structure wires the error cluster in tunnel to the error cluster out tunnel.
a) Sums occurances of specified Errors
b) Adds a specified numeric offset to 'error cluster in'
c) Translates specified Errors to Warnings
d) Clears all Errors
Additional:  Spot the bug/feature/oversight
Comments
LordNobady
C
The bug/feature/oversight is that with an empty array the VI reacts as D ( so D is correct to in a way )
Learning LabVIEW since January 2013
crossrulz
Knight of NI
The intended answer is C.  Really should use shift registers with FOR loops.  Didn't we recently have a question on that?
GCentral
adiveppa
Ans is C
RAMESHB
Ans id C. i dont no correct answer  just i am guessing
LordNobady
that is a good thing D is just as correct as C in this case.
MrStevenUND
C.
The bug is the error cluster input stops at the case statement and could cause a pop-up, depending if you have automatic error handling enabled or disabled in the options menu.
mini09
Active Participant
I`m not sure about the answer, The bug might be the Bundle by name doest have the cluster reference of the error in cluster so which may be an another error in cluster. I would be expecting some good review on the answer...
SercoSteveB
Active Participant
Answer: C (and D).  Nice one LordNobady, crossrulz, adiveppa, RAMESHB & MrStevenUND.
My bug/oversight/feature was indeed the lack of shift registers on the Error Cluster tunnels in and out of the FOR Loop.
LordNobady The bug/feature/oversight is that with an empty array the VI reacts as D ( so D is correct to in a way )
crossrulz
An interesting one I had not considered is....
MrStevenUND The bug is the error cluster input stops at the case statement and could cause a pop-up, depending if you have automatic error handling enabled or disabled in the options menu.
ashwinilele
C
