The Daily CLAD
Community Browser
Re: Error Handler #2
SercoSteveB
Active Participant
Which of the following is displayed following execution of the VI?
Comments
Not applicable
a)
crossrulz
Knight of NI
A
GCentral
mini09
Active Participant
A
LordNobady
A
Learning LabVIEW since January 2013
H.T.1981
A
Michalph
A
MrStevenUND
A
RaniJ37
what is the correct answer.. is it A?..
ljbandres
A
SercoSteveB
Active Participant
அனிதா26
Can anyone pls explain why option A is the answer?
crossrulz
Knight of NI
Take a look at the help document for the General Error Handler and it will become very obvious.
GCentral
AuZn
Hate to be that guy, but the output depends on error in. If there is error in error in, then that error will pop up, otherwise it would be the error specified in error code.
