Identify the Event Structure Elements labelled below?
a) Event Selector, b) Dynamic Event Terminal, c) Event Filter Node, d) Event Data Node
b) Dynamic Event Terminal, b) Event Selector, c) Event Filter Node, d) Event Data Node
c) Event Selector, b) Dynamic Event Terminal, c) Event Data Node, d) Event Filter Node
d) Dynamic Event Terminal, b) Event Selector, c) Event Data Node, d) Event Filter Node
