The Event Structure in the following VI has only been configured with a Timeout event. The VI is run and then the user selects the ‘stop’ button.
Which of the following statement(s) is TRUE for the execution?
a) The VI stops immediately
b) The VI stops following the timeout period
c) The VI does not stop
d) The VI only stops if the status of the ‘stop’ button is TRUE when the execution looks at the Conditional Terminal of the While loop
