What does the following LabVIEW Node return?
a) The path to the Windows Recycle Bin
b) The path to the Temporary Directory defined within LabVIEW
c) The path to the Default Directory defined within LabVIEW
d) The path to the Default Data Directory defined within LabVIEW
