Which of the following most closely matches the sizes of the files generated by the VI?
a) steve1.txt is the same size as steve2.txt
b) steve1.txt is larger than steve2.txt
c) steve1.txt is smaller than steve2.txt
d) Neither steve1.txt or steve2.txt is created due to errors
