Which of the following most closely describes the sizes of the files generated by the following VI?
a) steve.txt is the same size as steve2.txt
b) steve.txt is larger than steve2.txt
c) steve.txt is smaller than steve2.txt
d) steve2.txt is the larger as steve.txt was not created due to an error
