Which of the following is TRUE following execution of the VI?
a) SercoSteveB.txt is empty and 'error out' contains an error
b) SercoSteveB.txt is empty and 'error out' does not contain an error
c) SercoSteveB.txt contains LabVIEWRocks and 'error out' contains an error
d) SercoSteveB.txt contains LabVIEWRocks and 'error out' does not contain an error
