The Daily CLAD
Community Browser
Re: Fixed Point Equality
SercoSteveB
Active Participant
What is the value of 'Boolean Out 2' following execution of the VI?
a) TRUE
b) FALSE
Comments
crossrulz
Knight of NI
A
MrStevenUND
A.
From http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/numeric_data/#FXP_overflow:
When you use the Comparison functions to compare fixed-point numbers, LabVIEW ignores the overflow status and compares only the numbers. For example, if you use the Equal? function to compare a fixed-point value of 1.5 with an overflow status of TRUE to a fixed-point value of 1.5 with no overflow status, LabVIEW returns TRUE.
mini09
Active Participant
Initially my suggestion was B, After MrStevenUND post I go with A.
Thank you MrStevenUND
Ihab
A
SercoSteveB
Active Participant
Answer: A.  Nice one crossrulz, MrStevenUND, gnshmrthy & Ihab
Nice snippet of info MrStevenUND thanks.
