The Daily CLAD
Community Browser
Re: Flatten Numerics to String
SercoSteveB
Active Participant
What is Array Output following execution of the VI?
Comments
crossrulz
Knight of NI
D
GCentral
Not applicable
D.
SOM19
D
LordNobady
D
Learning LabVIEW since January 2013
MrStevenUND
D
mini09
Active Participant
D
SercoSteveB
Active Participant
Answer: D.  Nice one crossrulz, DavidCorney, SOM19, LordNobady, MrStevenUND & gnshmrthy.
Flatten to String is converting each successive byte of the data in into a character.  The number of bytes in each of the different numeric types is built into the array.
sahils
Can I get a little more explaination on this.
SercoSteveB
Active Participant
Hi sahils.  Flatten to String will flatten anything to a binary string.  The data you pass to flatten is translated on a byte by byte basis into binary.  NOTE:  If the data type you pass to Flatten to String is a non-scalar type (of undefined size) such as a strings and arrays  Flatten to String will by default add header information to the beginning of the string that defines the size of the non-scaler type that was translated.
ashwinilele
D
mssorters
D
Rathan123
what is the use of binary string and How to identify/expect the input from output binary string??
Rathan
crossrulz
Knight of NI
It is used a lot in TCP/IP communications since you have to write a string out.  I have also had to use it when talking to a PLC over Ethernet/IP.
One of the more unexpected places I use it is for interprocess communications.  I like to use queues with a string data type and then I can embedd the command and any parameter data in the string.  It is a derivative of using a cluster with a string and variant for sending commands.
As far as knowing what the data in the binary string is, well, you don't know.  You just have to know who sent the data and how they want you to interpret it.
GCentral
