The Daily CLAD
Community Browser
Re: For loop iteration control #3
SercoSteveB
Active Participant
What is the value in Numeric Value Out after the following has executed?
a) 0
b) 5
c) 9
d) 12
Comments
SercoSteveB
Active Participant
Answer: D
For loop iteration count can be controlled by; the value wired to the Count (N) terminal, the size of an input array (with auto-indexing enabled) or optionally by a Conditional terminal.  If multiple specifications of iteration count are made (as in the question) the loop will always opt for the fewest number of iterations.  In the question the loop will iterate 4 times defined by the size of the smaller of the two auto-indexed arrays.
At run time:
On the fourth (and final) iteration of the loop the values auto-indexed from the arrays are 4 & 8; these are added together and passed to the output tunnel.  Having completed four iterations the For loop completes and the value in the output tunnel is passed to Numeric Value Out.
mini09
Active Participant
this is nice example Mr.Steve .... Bravo!!!!!
swetha_sadula
ANswer:D
nmpundlik
Ans: d) 12
vksingh
12
thats it for now....
SOM19
D
ashwinilele
D 12
eleshrudra
d
R.Elesh
Andreas.Bernau
D
Rashme_SR
D
sac0071
D
M.P.Bharghavi
Ans: D
J.Nivetha
D
N.UdhayaKamali
12
Lily2016
D
Ronie7
D
Blake.N
D, With no shift registers values can not be carried through loops therefore the last iteration shall be 4+8
skian
D
