The Daily CLAD
Community Browser
Re: Format Value
SercoSteveB
Active Participant
What is String Array Out following execution of the VI?
Comments
kasliwal
C.
interesting one.
Format Value: The decimal input is being rounded off and then getting coverted.
Played around with last Format Value block, it seems default format string is %.6f
mini09
Active Participant
D.
I didn't knew that the round off will take for decimal value.
This is an nice example.
A.Bernau
not C: because of %04x has to be 04D3
not A: because of %d rounds, so it has to be 1235
but how about %.2f ?
I would guess it does not round the argument
So B?
I have to code it to confirm B (if not B then D) ...
..... It is D not B (%f rounds too)
crossrulz
Knight of NI
D
kasliwal
I made a mistake, D is correct.
4 significant digits in hex notation with zero padding. so 04D3 instead of 4D3. If it had been %4x, then 4D3 would be correct.
MrStevenUND
D would be the only one with consistant rounding...
I was first thinking B, but element 0 founds up while element 1 rounds up.  A has the opposite.
kasliwal, if you look close, %4x gives you [space]4D3 - padding to 4 characters with a space.  %04x pads with a zero.
rgbernatchez
D
SercoSteveB
Active Participant
Answer: D.  Nice one gnshmrthy, crossrulz, kasliwal, MrStevenUND & rgbernatchez.
A couple of things to understand here; space padding when using %04x and what happens when you pass an empty string for the format string.
mssorters
D
