The Daily CLAD
Community Browser
Re: Format into String #1
SercoSteveB
Active Participant
What are the contents of String Out following execution of the VI?
a) 1,2,3
b) 3,2,1
c) 1.00,2.00,3.00
d) 3.00,1.00,2.00
Comments
RAMESHB
Ans is D
        The format string format specifier (%code). Right-click the node and use Edit Format String. you can change also that %2,%3 and %1
see the different ouputs.
nmpundlik
Ans is D.
VSC
the resultant is D.
Asha_Nagaraj
Ans is D.
crossrulz
Knight of NI
D
I almost forgot about the $ to select the input.  I never use it.  But the format string is one of my favorite functions.
GCentral
GayatriT
The ans is D
adiveppa
ans is D
Kumarhatti
Ans is : D
SercoSteveB
Active Participant
Answer: D.  Nice one RAMESHB, nmpundlik, VSC, Asha_Nagaraj, crossrulz, GayatriT, adiveppa & Kumarhatti
You'd probably want to generate the format string programatically rather than using a constant as shown in the question.
jagadishj
Ans is D
mini09
Active Participant
agreed D,,,,,
ersmt444
Image broken
skian
D
