With Automatic Tool Selection enabled or with Connect Wire selected from the Tools Palette, what operation is performed in response to the keyboard shortcut: CTRL-LEFT CLICK on an input terminal of a Add function shown below?
a) The Control and wire connected to the selected terminal are deleted
b) The shortcut selects the Position/Size/Select tool
c) The shortcut switches the two input wires
d) No operation is performed
