Describe the functionality provided by the LabVIEW Node?
a) Returns the path associated with the specified refnum
b) Returns an array containing the path associated with the specified refnum
c) Returns the path associated with the temporary folder
d) Returns the path associated with a file it creates within the temporary folder
