Match the LabVIEW Shortcut with the descriptions.
a) Ctrl-.
b) Ctrl-Shift-Run button
c) Shift-Right-Click
d) Spacebar (drag)
e) Ctrl-drag a rectangle in open space
f) Ctrl-click input on function with two inputs
1) Disables preset alignment positions when moving objects labels or captions.
2) Adds more working space to the front panel or bloack diagram.
3) Stops the VI.
4) Displays a temporary version of the Tools palette.
5) Switches the two input wires.
6) Recompiles all VIs in memory.
