What does the For Loop 'P' Terminal, identified by the arrow, indicate?
a) That the loop is configured for parallel execution
b) That each iteration of the loop will pause for the duration, in milliseconds, passed to the terminal
c) That the loop is configured to run as a While loop
d) That the loop will pause when the iteration count terminal reaches the value passed to the terminal
