The Daily CLAD
Community Browser
Re: Nested Loops
SercoSteveB
Active Participant
What is Numeric Value Out following execution of the VI?
a) 0
b) 1
c) 2
d) Undefined (the VI does not stop)
Comments
DesasterMaster
NI Employee (retired)
The For-Loop will not execute...so A
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
A.Bernau
Yes, I agree the For Loop will not execute. As far as I learned few days ago here in this forum we getting default values 0.
So one default value 0 is equal to the other default value 0. The while loop stops and gives the third default value 0 to the output.
update: it is not the third default value, it is the init value of shift register, Thank you LordNobody for make it more precise
A
sriveni
A
LordNobady
A.
As Andreas says the For loop will not execute, default value = default value so the while loop gives the initialization from the shift register from the for loop as output.
with that set to 0 the answer is 0.
Learning LabVIEW since January 2013
crossrulz
Knight of NI
A
nik35324
A
MrStevenUND
A.
clendon.gibson@canrig.com
A
whitecr
Ans : A, for loop will not execute and while loop will stop in its first iteration.so What ever the value we are passing as input in shift register will be the output.
a.guzman_87
A
Mohammed_Atef
A
shargurudk
Ans:A for loop will not execute.
dg7318
A
ashwinilele
A... For loop does not execute
SercoSteveB
Active Participant
Eng_Mohammad_Wa
Ok
M.P.Bharghavi
Ans:A
0
