The Daily CLAD
Community Browser
Re: Not Cluster
SercoSteveB
Active Participant
Assuming the value of U8 Numeric, U16 Numeric, U32 Numeric, I8 Numeric, I16 Numeric and I32 Numeric are all set to 1.  What is Output Cluster following execution of the VI?
Comments
MrStevenUND
D
Can't be B since unsigned cant go negitive.  Assuming NOT is bitwise, C is incorrect for the signed values.  A had no change.
kasliwal
D.
'NOT' does bitwise complementation.
I had to look this up: I8 bit representation is interpreted in two's complement format. Therefore
11111110 for I8, gives - 2.
A.Bernau
As far as I remember for data representation for signed integer: If most significant bit is set it should be a negativ value and it cant be B how MrStevenUND explained....
answer is D
LordNobady
D The not makes the signed negative and the unsigned sty positive. D is the only option.
Learning LabVIEW since January 2013
crossrulz
Knight of NI
D.  It is doing a bitwise inversion.  From there, you need to know 2's Compliment.
GCentral
nik35324
D
mini09
Active Participant
D, for unsigned 8 bit integer the formula would be (255-1), and for Interger it would be (-x-1). I found this on wiki, http://en.wikipedia.org/wiki/Bitwise_operation
SercoSteveB
Active Participant
M.P.Bharghavi
Ans:D
