The Daily CLAD
Community Browser
Re: Numeric Array Functions
SercoSteveB
Active Participant
What are Numeric Value Out 1 and Numeric Value Out 2 following execution of the VI?
a) Numeric Value Out 1=1, Numeric Value Out 2=6
b) Numeric Value Out 1=21, Numeric Value Out 2=208
c) Numeric Value Out 1=21, Numeric Value Out 2=720
d) Numeric Value Out 1=720, Numeric Value Out 2=720
Comments
Musale
numeric out1=21
numeric out2=720
SercoSteveB
Active Participant
Nice one Musale.  Question amended,
nmpundlik
Answer is C.
crossrulz
Knight of NI
C
You don't really need to find the actual results to figure this one out.  You can do some estimates that will weed out the obvious wrong answers.
MrStevenUND
C.
JGmitter
C.  Estimation is key.
LordNobady
C
Learning LabVIEW since January 2013
jagadishj
The answer is C.
RAMESHB
Answer is C.
SercoSteveB
Active Participant
Answer: C. B.  Nice one Musale, nmpundlik, crossrulz, MrStevenUND, J-MACK, LordNobady, jagadishj & RAMESHB
Yep; it is good to slide in some exam technique into the questions identifying the simpler LabVIEW concepts.  No need to complete the operations in this one, estimate (thanks crossrulz & J-MACK) and save yourself some valuable time in the exam.
See below.
mini09
Active Participant
when i run with I32 data type the answer is C. if i run with the U8 the answer is B so according to the given question B should be the answer.
SercoSteveB
Active Participant
Well at least one of us is paying attention.  Nice one gnshmrthy kudos to you.
Answer: B.  Nice one gnshmrthy.
Slightly embarrassing for me as I can now remember adding this little gotcha...and managed to get myself.
mini09
Active Participant
Thanks Steve.
Joseph.Vitale
C. Thank you so much for supplying all of these qestions.
aqz
hi can anybody tell me how 208 came?
crossrulz
Knight of NI
The data type is a U8.  Therefore, once the value goes above 255 (0xFF), it must roll over (256 => 0).  The easiest way to do this is to just drop any of the extra bits (just keep the lower 8 bits).  When you do this, 720 (0x2D0) becomes 208 (0xD0).
aqz
ok got it.....we need to start counting with hex values, what i did was to convert the decimals like 255 + 255 giving closest value to 720, which is 210 i guess...thanks
ashwinilele
B. Because of U8
Otherwise
Ans C
s.vishal91
I'm getting 21 and 255...can someone tell me wer im goin wrong??
mini09
Active Participant
Hi vishal, you shouldn't be getting 255. Can you make a snippet of your code and share it.
s.vishal91
s.vishal91
The array elements are same as given in the question..
s.vishal91
sorry...got it...forgot make the array u8
s.vishal91
But, can u explain me how?
crossrulz
Knight of NI
How what?  Please be more specific with your questions.
I think what you are seeing is the Add Array Elements and the Multiply Array Elements are working with a DBL floating point array.  So the results will be 21 and 720.  But the indicators are U8, so the 720 is being coerced to the maximum U8: 255.
s.vishal91
Can you explain you earlier post?
crossrulz
Knight of NI
What part of it do you not undersand?
skian
c
