What are the values of String Out, Boolean Out, Numeric Out and Numeric Array Out following execution of the VI?
NOTE: The original post "The Daily CLAD" - post number 9, can be found here. Oh the nostalgia!!
a) String Out = "SteveLikesLabVIEW", Boolean Out = TRUE, Numeric Out = 5, Numeric Array Out = {0}
b) String Out = "SteveLikesLabVIEW", Boolean Out = FALSE, Numeric Out = 5, Numeric Array Out = {0,1,2}
c) String Out = <empty string>, Boolean Out = FALSE, Numeric Out = 0, Numeric Array Out = {0}
d) String Out = <empty string>, Boolean Out = FALSE, Numeric Out = 0, Numeric Array Out = <empty array>
