The FP.PanelBounds property of a VI (example shown below) returns a cluster defining the Front Panel Window Panel Bounds of the referenced VI with reference to the display. Assuming a single monitor display, which corner of the display is at the Panel Bounds {0,0,0,0} as shown in the Front Panel Window:Panel Bounds control below?
a) Top Left corner
b) Bottom Left corner
c) Top Right corner
d) Bottom Right corner
