The Daily CLAD
Community Browser
Quick Drop: 3 of 5
SercoSteveB
Active Participant
Which of the following are Quick Drop CTRL-Key Shortcuts provided by LabVIEW?
a) Remove and Rewire - Removes the selected block diagram object(s) and any wires and constants connected to the selected object(s), and connects wires of identical data types that were wired to the inputs and outputs of the deleted object(s).
b) Replace - Replaces the selected panel or diagram object(s) with the object specified by name in the Quick Drop dialog box.
c) Insert - Inserts the object specified by name in the Quick Drop dialog box on the selected wire(s) on the diagram.
d) Wire All Terminals - Creates controls and indicators for all unwired inputs and outputs of the selected block diagram object(s).
e) Move Labels - Repositions the visible labels or captions of top-level front panel and block diagram objects to be consistent with the "Default label position" settings in Tools > Options.
f) View as Icon - Toggles the 'View as Icon' display for the selected objects.
g) VI Server Rename - Changes the VI Server class of the selected property node(s), invoke node(s), and/or Class Specifier Constants, to the class typed in the Quick Drop window.
h) Multiple Objects Together - Connects compatible terminals between multiple selected diagram objects.
Comments
