The Daily CLAD
Community Browser
Re: Rotate Left with Carry
SercoSteveB
Active Participant
What are Numeric Value Out 1 and Numeric Value Out 2 following execution of the VI.
a) Numeric Value Out 1 = 0x468ACF12, Numeric Value Out 2 = 0x468ACF02
b) Numeric Value Out 1 = 0x2468ACF0, Numeric Value Out 2 = 0x2468ACF1
c) Numeric Value Out 1 = 0x0ECA8643, Numeric Value Out 2 = 0x0ECA8642
d) Numeric Value Out 1 = 0x2468ACF1, Numeric Value Out 2 = 0x2468ACF0
Comments
LordNobady
D i think
Learning LabVIEW since January 2013
nmpundlik
Answer is D.
RAMESHB
I got the Answer D like this what is the problem here can any one tell me
                         Numaric value out 1 is 0x2468ACF0
                         Numaric value out 2 is 0x2468ACF1
                          answers is interchange
SercoSteveB
Active Participant
Question modified. Any better?
JGmitter
Answer is D.
crossrulz
Knight of NI
D
Another one of my favorite functions that people don't seem to know about.
MrStevenUND
D.
2verb
D.
Another one I used all the time when I wrote assembly, but not so much in any higher level language.
Asha_Nagaraj
D.
SercoSteveB
Active Participant
mini09
Active Participant
agreed D as well....
Kapur
Question- do the bits get rotated left? Like shown here
https://www.youtube.com/watch?v=vw3mJFZICkI
crossrulz
Knight of NI
Except for the fact that you get to specify what the carry input is.
Kapur
Thank you for your answer. x12345678 is 10010001101000101011001111000. If I rotate each bit one bit to the left (from LSB to MSB), I should get 00100011010001010110011110001. The MSB was 1, it is now 0. Did I understand correctly?
A.Bernau
http://en.wikipedia.org/wiki/Logical_shift
http://zone.ni.com/reference/en-XX/help/371361L-01/glang/rotate_left_with_carry/
D
I still prefer the term shift instead of rotate, rotate is misleading.
But LabVIEW help is quite clear (see link)
Akhil_shah
Please can any one explain it in detail that how these 0x2468ACF1 and 0x2468ACF0 answer came.
crossrulz
Knight of NI
Akhil_shah,
Look at the values in a binary format and it will become a lot more obvious (do make sure you are seeing all 32 bits).  We are just shifting all of the bits to the left by one location and then specifying what value goes in the LSb (Least Significant Bit).
skian
D
