The Daily CLAD
Community Browser
Re: Rotate String
SercoSteveB
Active Participant
What is String Out following execution of the VI?
a) SteveLikesLabVIEW
b) WEIVbaLsekiLevetS
c) teveLikesLabVIEWS
d) SWEIVbaLsekiLevet
Comments
LordNobady
A
Learning LabVIEW since January 2013
heavypoet
C.
Rotate string leaves first character last. For loop repeats the same operation 17 times.
nik35324
C
crossrulz
Knight of NI
C
Notice there are no shift registers...
MrStevenUND
C
mini09
Active Participant
C...
Steve, I hope this was same question as on August 22nd.
kavyanaresh
Ans:C
Repeated the same question....
yash06
c
SercoSteveB
Active Participant
Hi gnshmrthy & kavyanaresh.
It was a complete duplication.  I had no idea I had done that one before.  I re-wrote it and everything.
Yep, the exact same question......that's awesome if not slightly embarrassing.....  .
Ihab
C
Borsod-Abaúj-Ze
The C is the correct answer. Only the first character goes to the end.
Pankajusic
C
SercoSteveB
Active Participant
Answer: C.  Nice one heavypoet, nik35324, crossrulz, MrStevenUND, gnshmrthy, kavyanaresh, vijay yashwanth, Ihab, Borsod-Abaúj-Zemplén & Pankajusic.
Here we are rotating the same input string a number of times, defined by the length of the input string.
I think it is really easy to assume that a VI uses the constructs that are appropriate for the operations inside the FOR Loop, rather than actually looking at ther constructs used.  As crossrulz points out Shift Registers would be appropriate for this type of VI, but standard tunnels are used.
eleshrudra
C.
its rotating same string so always a same output.
teveLikesLabVIEWS
R.Elesh
