The Daily CLAD
Community Browser
Re: Searching Numeric Arrays
SercoSteveB
Active Participant
What are the values of Numeric Value Out 1 and Numeric Value Out 2 following execution of the VI?
a) Numeric Value Out 1 = 0, Numeric Value Out 2 = 5
b) Numeric Value Out 1 = 1, Numeric Value Out 2 = 4
c) Numeric Value Out 1 = 4, Numeric Value Out 2 = 1
d) Numeric Value Out 1 = 5, Numeric Value Out 2 = 0
Comments
Vish07
D
LordNobady
D
Learning LabVIEW since January 2013
mini09
Active Participant
I tried executing since the search 1D array output is -1 the array out first subarray is zero and array out of second subarray is 5.
My option is A
A.Bernau
A
MrStevenUND
A.
The search string is looking for "2" After the 3rd element, it doesn't find it and output is -1.  This puts the split before the first element of the incoming array.  Therefore the Array size of the top output is 0, bottom is 5.
nik35324
A
crossrulz
Knight of NI
A
GCentral
kasliwal
A.
because 'search 1D array' returns -1
'Split 1D array' returns 1st array as empty, 2nd array same as input array.
SercoSteveB
Active Participant
Answer: A.  Nice one gnshmrthy, Andreas23, MrStevenUND, nik35324, crossrulz & kasliwal.
Thanks for the explanantions gnshmrthy, MrStevenUND, & kasliwal.
gdhanson
You will get the same result if the output of the Search 1D Array is a 0, as shown below
VenkatStony
Answer A  Nice one Thanks Steve..
M.P.Bharghavi
Ans:A
Numeric1=0,Numeric2=5
