The Daily CLAD
Community Browser
Re: Shift Registers and Local Variables
SercoSteveB
Active Participant
The value in 'Numeric Value In' is 5.  What are the values of 'Numeric Value In' and 'Numeric Value Out' following execution of the VI?
a)      Numeric Value In=5, Numeric Value Out=12
b)      Numeric Value In=7, Numeric Value Out=11
c)      Numeric Value In=9, Numeric Value Out=10
d)      Numeric Value In=11, Numeric Value Out=12
Comments
mini09
Active Participant
the ans is D. when the loop runs first time the value 4 is initialized to the numeric value in read and the second loop process the value 11 is initialized by using shift register. then the value 12 passes out of the loop to numeric value out.
RustyStrings
I agree the answer is D
One thing this demostrates is a dataflow issue
At one time I would have thought that when the Numeric Value In was change to 4 on the first iteration it looks like 4 would be passed in on the 2nd iteration
but dataflow  only allows the local variable to read once, if it changes afterwards it will not be read again until the next time the code is executed
the loop will use the value that was input the first time
(Just a note for anyone interested)
Knowing when your controls are being read is important
I once had a loop that did some I/O in a long chain of code there was a stop control in the loop
when running the code after the first vi in the chain was done I pressed the stop button, but the the loop went on to the next iteration
it soon occured to me that the stop button had already been read for this iteration and would have no effect until the next iteration
you need to tie the control in at the end of the chain using a sequence (error in error out connected) in order for it to be read after the chain is executed
SercoSteveB
Active Participant
Answer:D  Nice one gnshmrthy and RS.  As Rusty pointed out this question is primarily about data flow.  Remember to consider structures (loops, case structures, event structures etc.) the same as other BD elements in terms of data flow.
Data Flow Programming - From NI.com
'A block diagram node or structure must have all input data available before the node or structure can execute,  on execution the values of the inputs are read (from the question; it is at this point the value of the Numeric Value In local is read, once).  When execution is complete; data is passed to the outputs.'
mini09
Active Participant
hw to make the program to go back to the initial values after running the program for once?
RustyStrings
You can either select Edit.Reinitialize Values to Default (this will do all controls and indicators in the vi) you would have used the make default first for it to have the proper effect
or you can right click on individual controls and indicators and selcet the same thing (under Data Options)
srinath@elsys.in
Ans is
At first iteration
Numeric Value In=6, Numeric Value Out=10
secon iteration
Numeric Value In=11, Numeric Value Out=10
RAMESHB
D
ashwinilele
Ans is D
skian
D
