The Daily CLAD
Community Browser
Re: Spreadsheet String to Array
SercoSteveB
Active Participant
What is the value of Numeric Value Out following execution of the VI?
a) 17
b) 18
c) 19
d) 20
Comments
Ajay_MV
Active Participant
Answer is a) 17
Ajay MV
mini09
Active Participant
In this Program the For Loop with auto Index enables shows that the loop will run for array no`s bcz the N terminal is not connected.
So the spreadsheet string to array reads the value of the string. here %s is a function which converts the spreadsheet string to array of Strings.
the output of Spreadsheet string to array converts the 1x3 or 3x1 array as output.
Each time when the loop is executed the executes it calculates the value of string.
Steve=5
Likes=5
LabVIEW= 7
here the shift register helps to add the previous value so the value of Numeric Value ot is 17 and option A is correct.
SercoSteveB
Active Participant
Answer: A.  Nice one AjayvigneshMV & gnshmrthy.  Nice explanation gnshmrthy.
RAMESHB
Ans is A)17
manolito
does it mean that element of the string needs to be "," delimmited?
crossrulz
Knight of NI
See that comma constant being wired into the Spreadsheet String to Array function?  That is setting the delimiter.  It can be whatever you want.  In this case, it is a comma.  So the string is comma delimited.
manolito
thank you crossRuiz.
Coul you explain to mee in a simple example how the for loop works?
thank you again.
manolo
ashwinilele
A
skian
A
