In the following VI, Numeric Value In is wired to an item on the boundary of a Stacked Sequence Structure. What functionality does the item provide?
a) Allows data to be passed from one frame to any other frame in a Stacked Sequence structure.
b) Allows data to be passed from one frame to the next frame in a Stacked Sequence structure.
c) Allows data to be passed from one frame to any subsequent frame in a Stacked Sequence structure.
d) Allows data to be passed out of a Stacked Sequence structure.
