The Daily CLAD
Community Browser
Re: String Constants with '\' Codes Display
SercoSteveB
Active Participant
Assuming Sring Constant is set to '\' Codes Display.  What are the contents of Boolean Array Out following execution of the VI?
a) {T,F,F}
b) {F,T,F}
c) {F,F,T}
d) {T,T,T}
Comments
crossrulz
Knight of NI
A
LordNobady
A
Learning LabVIEW since January 2013
nik35324
A
dhanalakshmi.ja
Ans is A (T,F,F)
shree_bala
A
Baltur
A) \n is line feed.
I just now noticed you started again this year, so welcome back.
MrStevenUND
A
sac0071
A
ashwinilele
A
AuZn
The End of Line constant should be platform dependent. On Windows it is /r/n, on Mac it is /r, and on Linux it is /n.
However, given that there is no Linux version of Labview, this question has a unique answer of A.
Could some one with a Mac version of Labview test if EOL is /r there? i.e. if change the string to \r, would the result be {F,T,T}?
crossrulz
Knight of NI
Yes there is (System Requirements for LabVIEW Development Systems and Modules).  Plus the newer cRIO uses an RT version of Linux.
I was waiting for somebody to mention different targets.  So for a Windows or Mac, you have A.  For Linux, the answer is {T,F,T}.  But since that isn't an option, the BEST answer is A.
AuZn
Oh I forgot about the RT targets. I actually have a myRio with RTlinux on it. I can confirm that the answer is {T,F,T} on the target.
pksusic
A
eleshrudra
answer is A
R.Elesh
chan1989
answer is A. Gotta figure out what the difference is between normal display and the backlash display.
M.P.Bharghavi
Ans:A
{T,F,F}
