The Daily CLAD
Community Browser
Re: String to 2D Array
SercoSteveB
Active Participant
What are the contents of Array Size Out following execution of the VI?
a) {1,3}
b) {1,5}
c) {1,6}
d) {2,3}
Comments
LordNobady
I go for D
Learning LabVIEW since January 2013
Sumithra_Nagappan
Ans D
crossrulz
Knight of NI
D
MrStevenUND
D.
I'm surprised both {2,3} and {3,2} aren't options.  I am always second guessing myself on which comes first... rows then columns.
VSC
The resultant is option D.
Asha_Nagaraj
Ans is D.
LordNobady
agree. the 2 and 3 combo is the easy part.
RAMESHB
Ans is D
adiveppa
ans is D
somashekar_kako
can any one explain it clearly
SercoSteveB
Active Participant
Answer: D  Nice one LordNobady, Sumithra_Nagappan, crossrulz, MrStevenUND, VSC, Asha_Nagaraj, RAMESHB & adiveppa.
Spreadsheet String To Array Function converts a spreadsheet string to an array of the dimension and representation of array type. This function works for arrays of strings and arrays of numbers.
By spreadsheet string; I think NI mean a string delimited by a character, Steve,Likes,LabVIEW is delimited by the commas.  In the example I have set up the Spreadsheet String To Array Function to break the string up by the commas.  In addition I have added and <CRLF> into the spreadsheet string to highlight what impact that has on the 2D output array.
What do we think the answer would be if the <CRLF> was missing from the spreadsheet string?
LordNobady
if the <CRLF> was not there the answer is B
LabVIEW and The wil merge
sumapatil
Answer is D
jagadishj
D is the write answer because of when you increasing this type of symbol(,) from both input of the string constant or one input side it will shown you how many used it.
mini09
Active Participant
Agreed D as well........
ashwinilele
D
skian
D
