The Daily CLAD
Community Browser
Text File Operations
SercoSteveB
Active Participant
Which of the following most closely matches the result of running the following VI?
NOTE:  Assume the user has the priviledge to perform all of the necessary file operations on the file SteveLikesLabVIEW.txt in the directory shown in the VI.
a) SteveLikeLabVIEW.txt is created, the file is empty, the VI generates an Error.
b) SteveLikeLabVIEW.txt is created, the file is NOT empty, the VI does NOT generate an Error.
c) SteveLikeLabVIEW.txt is NOT created, the VI generates an Error.
d) SteveLikeLabVIEW.txt is NOT created, the VI does NOT generate an Error.
Comments
