The Daily CLAD
Community Browser
Re: The Dataflow Paradigm #3
SercoSteveB
Active Participant
Which of the following is represented in the Block Diagram?
Comments
SercoSteveB
Active Participant
Answer:A
Remembering the dataflow paradigm: 'A block diagram node executes when it receives all required inputs. When a node executes, it produces output data and passes the data to the next node in the dataflow path. The movement of data through the nodes determines the execution order of the VIs and functions on the block diagram.'
somashekar_kako
answer is A
x and y
not(x and y) -----> 1
x or z
not(x or z)
x and (not(x and z))-----> 2
now perform OR logic with equaiton one and two
NOT(XandY)OR (X and NOT(X or Z))
SOM19
A
ashwinilele
A
eleshrudra
A
R.Elesh
Andreas.Bernau
A
sharmi2208
a
Lily2016
a
Ronie7
a
ersmt444
Image broken
vicky369
A
Blake.N
A
skian
A
