One to finish the theme.....![]()
Assuming initial values for Action Button and Stop Button of FALSE. The following VI is executed, the user performs a left mouse click and release on the Action Button. Which of the following most closely describes the result?
a) The value of the Stop Button is set to TRUE and the VI stops
b) The value of the Stop Button is set to TRUE and the VI does not stop
c) An error is generated and the VI does not stop
d) An error is generated and the VI stops
