Once again, a bit complex for the CLAD.
What behaviour does the following VI exhibit?
a) It makes all Controls and Indicators on the VI invisible
b) It makes all Controls and Indicators on the VI visible
c) It makes Numeric Control 1, Numeric Control 2, Boolean Control 1 and Boolean Control 2 visible or invisible; depending on the state of Boolean Control 3
d) It makes Boolean Control 3 Visible.
