The Daily CLAD
Community Browser
Re: Threshold Array
SercoSteveB
Active Participant
What are the contents of Numeric Array Out following execution of the VI?
Comments
robs777
d
Not applicable
D)
vijayb.chaudhari179@gmail
piease explain what exactly this threshold 1d array does?..SercoSteveB
crossrulz
Knight of NI
D
crossrulz
Knight of NI
Why don't you just look it up in the LabVIEW help?  Threshold 1D Array
nik35324
D
ya i understood it.
MrStevenUND
D
heavypoet
D
adamharriscpcc
We built this in class and it comes out with 0, 1.5, 2.  Can anyone explain?
crossrulz
Knight of NI
I'd have to see your code.  That sounds like you made a wiring mistake somewhere.
adamharriscpcc
yup, a typo, we had "11" instead of "1" but couldn't see that because the width of the array doesn't auto-resize.
LordNobady
D
Learning LabVIEW since January 2013
Jsoni
D
mini09
Active Participant
D
SercoSteveB
Active Participant
ersmt444
Hey Please help,
According to formula: y=y1+(x-x0)(multiply)y2-y1(divide)x2-x1
This formula is used for findout fractional index.
The values are taken below becuase 2.5 lies in between these values:
For index 0
x0=0;x1=;x2=2;x3=3;x4=4...
y0=1;y1=2;y3=3;y4=4;y5=5...
for index 1 and 2 will be somthing different..
For index 0,
where given values are as:
x1=1   y1=3
x2=2   y2=2
y=2.5
x we will be 1.5 after solving through formula.Remaining values can be solved similarly by changing the value of index from 1 and 2 and we will get values 0.5 and 0 respectively.So the answer should be for x:
1.5
0.5
0
I have done many examples related to this but here my LabVIEW program give the same answer as mentioned above.How?
ersmt444
I got the point.It is something different.Here the index remained same but moving from 0 to next and thus the value of index remained same until it reaches the maximum value.
