There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
I'd have to see your code. That sounds like you made a wiring mistake somewhere.
According to formula: y=y1+(x-x0)(multiply)y2-y1(divide)x2-x1
This formula is used for findout fractional index.
The values are taken below becuase 2.5 lies in between these values:
For index 0
x0=0;x1=;x2=2;x3=3;x4=4...
y0=1;y1=2;y3=3;y4=4;y5=5...
for index 1 and 2 will be somthing different..
For index 0,
where given values are as:
x1=1 y1=3
x2=2 y2=2
y=2.5
x we will be 1.5 after solving through formula.Remaining values can be solved similarly by changing the value of index from 1 and 2 and we will get values 0.5 and 0 respectively.So the answer should be for x:
1.5
0.5
0
I have done many examples related to this but here my LabVIEW program give the same answer as mentioned above.How?
I got the point.It is something different.Here the index remained same but moving from 0 to next and thus the value of index remained same until it reaches the maximum value.
