The Daily CLAD
Community Browser
Re: Type Cast & String To Byte Array
SercoSteveB
Active Participant
What is the value of Boolean Out following execution of the VI?
a) TRUE
b) FALSE
Comments
LordNobady
A
Learning LabVIEW since January 2013
crossrulz
Knight of NI
A
gmarz5
A
Michalph
A
MrStevenUND
A
lvrat
Active Participant
A
CLD
SwamyM
Ans : A
g_l_u_p
I'll go with A too
mini09
Active Participant
Answer is A. If I`ve some values in the U8 Array there is no change in the result?
LordNobady
no it is just the type to cast to. thy typecast only tells the compiler that from that moment on the value is to be seen as the given type. if the type is not compatible I don't know what it will do. In C it can crash.
WARNING it converts it at byte level not value level. so casting an int to a double will not give you the same value.
Typecasts are some of the most powerful programmers tools. ( and with grate power comes grate responsibility ) use with care.
JasonDiv
Can anyone explain to me this concept please?
crossrulz
Knight of NI
Which concept?  The Type Cast?  The Type Cast just changes how the raw binary data is interpreted.  In this case, the data in the string is being reinterpreted as a byte array (U8).  This is the same thing as using the String To Byte Array function.
JasonDiv
So the equal? is actually comparing data types instead of the actual values?
crossrulz
Knight of NI
No.  The Equal is comparing the data in the arrays.  It was set to compare Aggregates, which returns a single boolean for if the entire arrays were the same.  You can also setup the equal to compare Elements, which will return an array of booleans indicating if the corresponding elements were the same.
JasonDiv
Thanks crossrulz.. Am now a follower of the The Daily CLAD
erganesh
Condition is true
