Which of the following statements is TRUE regarding Type Def. and Strict Type Def.
NOTE: Multiple answers may apply.
a) A Type Def. or Strict Type Def. Terminal or Constant can be identified on the Block Diagram or Front Panel as it will have a black triangle in the top left hand corner
b) Any Terminal or Constant can be made into a Type Def. from the "Make Type Def." option in the right click shortcut of the item
c) If you drop a Type Def. control onto the Block Diagram, LabVIEW automatically creates a Control on the Front Panel
d) If you drop a Type Def. control onto the Front Panel, LabVIEW automatically creates a Terminal on the Block Diagram
