Assuming all of the Data Point Array In and Data Point Array Out terminals are of the same type defined (typedef) type.
Which of the following Block Diagrams is indicating the correct propagation of typedef information through the FOR Loop?
NOTE: Some Block Diagrams may have been modified through the power of GIMP
